Author Topic: SE 28.0.2 stack  (Read 1082 times)
at5dapa1
  • Hero Points: 24
SE 28.0.2 stack
« on: April 19, 2024, 05:06:58 PM »
Did a search for refs, jumped to one result and suddenly got this "mouse.ex 28072 _ECTimerCallback".
Log attached, not sure if reproducible....
SlickEdit Pro 2023 (v28.0.2.0 64-bit Qt5)
Build Date: April 3, 2024
Emulation: CUA
OS: Windows 10 x64
OS Version: 10.00.0
Memory: 26% Load, 8535MB/32464MB Physical, 10931MB/32464MB Page File, 4822MB/134217727MB Virtual
Screen Size: 1920 x 1200 (0 0 1920 1200), 1920 x 1200 (-1920 0 1920 1200)
Project Type: Cpp
Language: .c (C/C++)
Encoding: ACP (1252)
Installation Directory: D:\tools\totalcmd\Tools\dev\SlickEdit\core\ (non-removable drive,NTFS,271507MB free)
Configuration Directory: D:\tools\totalcmd\Tools\dev\SlickEdit\config\28.0.2\ (non-removable drive,NTFS,271507MB free)
Spill File: C:\Users\work\AppData\Local\Temp\slkspill.work.9056 (non-removable drive,NTFS,43141MB free)
Hotfixes:
D:\tools\totalcmd\Tools\dev\SlickEdit\config\28.0.2\hotfixes\hotfix_se2802_4_cumulative.zip Revision: 4   (currently loaded)
  • Hero Points: 535
Re: SE 28.0.2 stack
« Reply #1 on: April 20, 2024, 03:45:16 PM »
A hot fix is available for this.
Download the hot fix here:
https://www.slickedit.com/hotfixes
Then load the hot fix: Help>Product Updates>Load Hot Fix...
