Author Topic: Minimap font size  (Read 2833 times)
LBCEi
  • Hero Points: 21
Minimap font size
« on: May 03, 2024, 06:58:51 PM »
In 28.0.2, the minimap font size seems to keep resetting itself to the same size as the editor window font.  See screenshot attached.
I can fix it (temporarily) by right clicking in the minimap and selecting Unzoom and then Set Default Minimap Font Size.  It appears to happen each time I start SE, but I'm not sure that is the only time it happens (I rarely close SE).
  • Hero Points: 535
Re: Minimap font size
« Reply #1 on: May 03, 2024, 08:10:58 PM »
Try setting the font for "Unicode Minimap Windows" (Tools>Options>Appearance>Fonts). Set to something other than a built-in font like Default Unicode Font which isn't a real font (SlickEdit attempts to map this to something usable).
LBCEi
  • Hero Points: 21
« Reply #2 on: May 04, 2024, 12:55:06 PM »
Thanks, Clark.
I'll try that on Monday.
LBCEi
  • Hero Points: 21
« Reply #3 on: May 06, 2024, 03:25:41 PM »
It turns out that the minimap font is already set to a non-default font.  See attached screenshot.
  • Hero Points: 535
« Reply #4 on: May 06, 2024, 04:25:09 PM »
Try exiting SlickEdit and removing vrestore.slk and vrestore.xml. This will reset your tool windows and other auto restore data.
LBCEi
  • Hero Points: 21
« Reply #5 on: May 06, 2024, 08:18:34 PM »
Removing the vrestore files (by renaming them) didn't work.
  • Hero Points: 535
« Reply #6 on: May 06, 2024, 11:10:11 PM »
Maybe you can provide steps from a clean config on how to reproduce this.
vs - sc /tmp/config
LBCEi
  • Hero Points: 21
« Reply #7 on: December 06, 2024, 07:45:31 PM »
Sorry for letting this lie for so long.  I tried your suggestion (actually now using V29, which still shows the same issue when using my normal config folder).
Interestingly with the clean config, it seems to show the opposite problem.  The minimap font is extremely tiny.
Let me know if you have any other suggestions or I can provide any further information.
  • Hero Points: 535
« Reply #8 on: December 06, 2024, 07:59:23 PM »
We will need steps on how to reproduce this.
