Home
Help
Search
Login
Register
SlickEdit Community
SlickEdit Product Discussion
SlickEdit®
Excluding symbolic links
« previous
next »
Reply
Send this topic
Print
Pages:
1
2
Go Down
Author
Topic: Excluding symbolic links (Read 3364 times)
joecar
Senior Community Member
Hero Points: 9
engineer/gearhead
Re: Excluding symbolic links
Reply #15 on:
August 22, 2024, 08:58:37 PM »
$0.02 suggestion:
see attached, would skip symlinks, i.e. not add a file resulting from following a symlink.
This would avoid "duplicate" files, makes it easier to navigate tagged objects.
Report to moderator
Logged
joecar
Hero Points: 9
engineer/gearhead
Reply #16 on:
September 06, 2024, 05:09:53 PM »
Another way to look at this is as follows:
when adding files to a project, a file should not be added if it is already added
( but this would be more work than checking if the file is really a symlink )
Report to moderator
Logged
joecar
Hero Points: 9
engineer/gearhead
Reply #17 on:
October 01, 2024, 06:07:13 PM »
More info:
I invoked
SE
with the option
-ssymlink
and I did
File -> File Manager -> New File List
and I see this
( actual files have non-zero file size,
symlinks
have
zero
file size )
/* I chopped out the full pathname to make it easier to view */
> 0 5-22-2024 6:51p ----A ndp250\src\hal\mic.c
> 0 5-22-2024 6:51p ----A ndp250\src\hal\mic.h
> 0 5-22-2024 6:51p ----A ndp250\src\hal\ndp115_dnn_regs.h
> 0 5-22-2024 6:51p ----A ndp250\src\hal\ndp115_regs.h
> 0 5-22-2024 6:51p ----A ndp250\src\hal\ndp115_spi_regs.h
> 0 5-22-2024 6:51p ----A ndp250\src\hal\ndp120_dnn_regs.h
> 534106 5-22-2024 6:51p ----A ndp250\src\hal\ndp120_regs.h
> 0 5-22-2024 6:51p ----A ndp250\src\hal\ndp120_spi_regs.h
> 29847 5-22-2024 6:51p ----A ndp250\src\hal\ndp250a0_dnn_regs.h
> 579097 5-22-2024 6:51p ----A ndp250\src\hal\ndp250a0_regs.h
> 27311 5-22-2024 6:51p ----A ndp250\src\hal\ndp250a0_spi_regs.h
> 0 5-22-2024 6:51p ----A ndp250\src\hal\ndp_regs.h
> 0 5-22-2024 6:51p ----A ndp250\src\hal\notify.c
> 0 5-22-2024 6:51p ----A ndp250\src\hal\notify.h
> 0 5-22-2024 6:51p ----A ndp250\src\hal\pdm.c
> 0 5-22-2024 6:51p ----A ndp250\src\hal\pdm.h
> 0 5-22-2024 6:51p ----A ndp250\src\hal\pwr.c
> 0 5-22-2024 6:51p ----A ndp250\src\hal\pwr.h
> 0 5-22-2024 6:51p ----A ndp250\src\hal\ringbuf.c
> 0 5-22-2024 6:51p ----A ndp250\src\hal\ringbuf.h
> 0 5-22-2024 6:51p ----A ndp250\src\hal\sample.c
> 0 5-22-2024 6:51p ----A ndp250\src\hal\sample.h
> 0 5-22-2024 6:51p ----A ndp250\src\hal\sc_reg_alias.h
> 0 5-22-2024 6:51p ----A ndp250\src\hal\sensor.c
> 0 5-22-2024 6:51p ----A ndp250\src\hal\sensor.h
> 0 5-22-2024 6:51p ----A ndp250\src\hal\sensor_function_list.c
> 0 5-22-2024 6:51p ----A ndp250\src\hal\sensor_function_list.h
> 10129 5-22-2024 6:51p ----A ndp250\src\hal\serial.c
> 1142 5-22-2024 6:51p ----A ndp250\src\hal\serial.h
> 0 5-22-2024 6:51p ----A ndp250\src\hal\softmax.c
> 0 5-22-2024 6:51p ----A ndp250\src\hal\softmax.h
> 0 5-22-2024 6:51p ----A ndp250\src\hal\spi.c
> 0 5-22-2024 6:51p ----A ndp250\src\hal\spi.h
> 0 5-22-2024 6:51p ----A ndp250\src\hal\spl.c
> 0 5-22-2024 6:51p ----A ndp250\src\hal\spl.h
> 0 5-22-2024 6:51p ----A ndp250\src\hal\test.c
> 0 5-22-2024 6:51p ----A ndp250\src\hal\test.h
> 0 5-22-2024 6:51p ----A ndp250\src\hal\timer.c
> 0 5-22-2024 6:51p ----A ndp250\src\hal\timer.h
> 0 5-22-2024 6:51p ----A ndp250\src\hal\varring.c
> 0 5-22-2024 6:51p ----A ndp250\src\hal\varring.h
> 16499 9-26-2024 12:31p ----A ndp250\src\hal\video.c
> 934 6-06-2024 9:31a ----A ndp250\src\hal\video.h
Report to moderator
Logged
joecar
Hero Points: 9
engineer/gearhead
Reply #18 on:
October 01, 2024, 06:14:10 PM »
Background:
my project has many directories each containing many files and many
symlinks
to other files and directories located in other directories in the same project... this makes the tagging difficult to navigate since each symbol shows up in N instances.
Report to moderator
Logged
Reply
Send this topic
Print
Pages:
1
2
Go Up
« previous
next »
SlickEdit Community
SlickEdit®
