Author Topic: Switch params in PowerShell are formatted weirdly  (Read 1213 times)
spongyryno
« on: June 17, 2024, 08:40:13 PM »
This is a negative side-effect of this: https://community.slickedit.com/index.php/topic,19187.msg
If you don't apply that, the "switch" keyword doesn't get formatted as a keyword. But if you do, you get another bad behavior:
Create a new PowerShell script, such as foo.ps1.
Copy/paste the following code to define the parameters this script will take:
param(
[string]$Variable1,
[int]$Variable2,
[bool]$Variable3,
[switch]$Variable4,
[string]$Variable5,
[int]$Variable6,
[bool]$Variable7,
[switch]$Variable8
Now, one by one, go to the end of each parameter line and hit <enter>. Note how they all work correctly except for the switch one.
Can we get this fixed?
  • Hero Points: 535
Re: Switch params in PowerShell are formatted weirdly
« Reply #1 on: June 17, 2024, 09:51:32 PM »
I'm not able to reproduce this but maybe I'm not following what you are saying needs to be done to reproduce this.
What happens with a default config: vs -sc c:\temp\newconfig
Please post a sample file instead of copy/paste.
Please post your user.cfg.xml.
Email support if you prefer
« Last Edit: June 17, 2024, 09:59:16 PM by Clark »
