Author Topic: Slick-C Stack in Version Control > History Diff  (Read 1157 times)
  • Hero Points: 521
« on: July 11, 2024, 06:13:35 PM »
To reproduce the issue:
1) Open a file that is controlled under Git
2) Version Control > History Diff for ...
3) Right click in the editor control
Stack trace written to file: /tmp/vsstack.XXXXXX
 Control -ctlfile1-readonly referenced but does not exist
diffedit.ex 4632 diffedit:edit_window_rbutton_up()  p_window_id: 337  p_object: OI_EDITOR  p_name: _ctlfile1  form_name: _history_diff_form
diffedit.ex 11218 diffedit:_EditControlEventHandler()  p_window_id: 337  p_object: OI_EDITOR  p_name: _ctlfile1  form_name: _history_diff_form
diffedit.ex 12808 _diff_form._ctlfile1.range_first_nonchar_key-all_range_last_nonchar_key()  p_window_id: 337  p_object: OI_EDITOR  p_name: _ctlfile1  form_name: _history_diff_form
dlgeditv.ex 7514 show(-modal -xy  _history_diff_form,@24462,eeddced489df362b22fafcbfa1b31aa7a96e1403,0)  p_window_id: 459  p_object: OI_MINIHTML  p_name: ctlminihtml1  form_name: _svc_query_output_form
svc.ex 17573 svc_history_diff(/home/XXXXXXXX.local/XXXXXX/.../XXXXXXX.cpp,,eeddced489df362b22fafcbfa1b31aa7a96e1403,1)
  p_window_id: 530
  p_object: OI_EDITOR
  p_name:
svcquery.ex 3603 _svc_query_output_form.ctlminihtml1.on_change(32,histdiff:eeddced489df362b22fafcbfa1b31aa7a96e1403)  p_window_id: 530  p_object: OI_EDITOR  p_name:
controls.ex 1444 _ul2_minihtm.lbutton_down()  p_window_id: 530  p_object: OI_EDITOR  p_name:
There is no "_ctlfile1_readonly" control is on the history diff form.  The right click handler should check if it's there before using it.
  • Hero Points: 535
Re: Slick-C Stack in Version Control > History Diff
« Reply #1 on: July 11, 2024, 08:09:39 PM »
Reproduced. We will look into this
  • Hero Points: 535
« Reply #2 on: July 11, 2024, 08:53:31 PM »
A hot fix is available for this.
Download the hot fix here:
https://www.slickedit.com/hotfixes
Then load the hot fix: Help>Product Updates>Load Hot Fix...
