Author Topic: Main menu missing  (Read 646 times)
unMinou
Main menu missing
« on: November 09, 2024, 02:13:17 AM »
I've used SlickEdit for the past 23 years at work and always had a main menu, now as I am retiring I bought my own copy but the standard version and not the professional as I have at work. I realized that at work I only use the beautify function so it is not worth for me to pay an extra $150 or more.
As I use this SlickEdit version I cannot figure out how to enable the main menu.
How do I replace the ICONs with actual menu like we have in all normal applications?
Is that a bug in the version 28 or just a secret command to enable it?
Michel
  • Hero Points: 153
Re: Main menu missing
« Reply #1 on: November 09, 2024, 02:36:13 PM »
This a bug - you can shut the menu off, but it requires a bit of work. Having it simply disappear is a bug.
Is this a machine that had an existing configuration?
  • Hero Points: 534
« Reply #2 on: November 09, 2024, 03:21:54 PM »
Maybe your configuration is trashed.
You can start SlickEdit with a clean config like this:
vs -sc c:\temp\newconfig
OR
vs -sc /tmp/newconfig
The menu bar should get displayed with a clean config.
