Author Topic: Tools->OS Shell doesn't work in macOS  (Read 3302 times)
bsun
« on: November 13, 2024, 02:06:13 PM »
My OS is macOS Sequoia 15.1.
My device is MBP with Apply M1 Pro.
Thanks for the help.
  • Hero Points: 544
Re: Tools->OS Shell doesn't work in macOS
« Reply #1 on: November 13, 2024, 02:26:00 PM »
This is probably a permissions problem.
Open a terminal and try the following command:
osascript /Applications/SlickEditPro2023.app/Contents/MacOS/TerminalPath.applescript
Apple has a lot of permissions restrictions.
bsun
« Reply #2 on: November 13, 2024, 02:58:05 PM »
Thanks, but not work.
osascript: /Applications/SlickEditPro2024.app/Contents/MacOS/TerminalPath.applescript: No such file or directory
  • Hero Points: 544
« Reply #3 on: November 13, 2024, 04:00:46 PM »
Make sure the terminalPath.applescript file exists. You may have to search for it. Should be in Contents/macOS. Looks like osascript is getting found.
patentedidiot
« Reply #4 on: November 13, 2024, 05:29:23 PM »
Some older applications or plugins may need to run in x86 compatibility mode.
Also Update Command Line Tools:
Open Terminal and run:
xcode-select --install
as for permissions, go to System Preferences > Security and privacy > Privacy
In Full Disk Access, Files and Folders and Accessibility, add the application if it’s not already listed. Make sure that Terminal and any other shell/IDE you use have proper permissions
bsun
« Reply #5 on: November 13, 2024, 10:42:09 PM »
There is no terminalPath.applescript file.
  • Hero Points: 544
« Reply #6 on: November 14, 2024, 02:23:25 AM »
It looks like terminalPath.applescript is missing from the arm installers. Probably been broken for a while.
You can place the attached file in Contents/MacOS to fix this problem
bsun
« Reply #7 on: November 14, 2024, 05:54:43 AM »
It works now. Thank you.
  • Hero Points: 544
« Reply #8 on: November 14, 2024, 02:01:56 PM »
Thanks for reporting this issue
