Author Topic: How to set the size of the context tagging prompt box?  (Read 1003 times)
sjgsjg
« on: November 14, 2024, 07:05:10 AM »
How to set the size of the context tagging prompt box? Some characters are displayed overlapping
sjgsjg
Re: How to set the size of the context tagging prompt box?
« Reply #1 on: November 14, 2024, 07:32:32 AM »
The prompt for short character length is displayed correctly,Longer character prompts will only overlap when displayed
Need to increase the width of the prompt box or automatically adjust its width
  • Hero Points: 534
« Reply #2 on: November 14, 2024, 02:11:58 PM »
This dialog is supposed to auto-size the width. I can't reproduce this. I guessed your on windows given your history. What OS are you on? I also tested Linux.
What happens if you try a default config:
vs -sc c:\temp\newconfig
sjgsjg
« Reply #3 on: November 15, 2024, 02:23:28 PM »
I try a default config "vs -sc c:\temp\newconfig" ,The problem still exists,
my os is windows10 pro 64bit 19045.3324
Attach "screen.h" is test file
  • Hero Points: 534
« Reply #4 on: November 15, 2024, 02:51:38 PM »
I still can't reproduce this. In my previous tests I bashed on it pretty good with no problems.
What version of SlickEdit are you running?
sjgsjg
« Reply #5 on: November 16, 2024, 02:02:03 AM »
I don't remember the previous version, but I've tested that all versions since v27 to v29  have this problem
It looks like the problem is only presented in the first line, the line below is showing up normally, and there is a lot of white space to the right of the example of the attachment
« Last Edit: November 16, 2024, 02:08:22 AM by sjgsjg »
  • Hero Points: 534
« Reply #6 on: November 16, 2024, 11:47:18 PM »
Post everything you can about your display and video card.
Also, do you own multiple machines? If so, please test this issue on one of your other machines.
