Author Topic: PASV error on save  (Read 1132 times)
jorick
  • Hero Points: 17
PASV error on save
« on: November 27, 2024, 06:46:04 PM »
I'm developing a web page in PHP, and almost every time I save the file, I get the following error dialog box pop up:
Could not determine address/port from PASV
After clicking OK, I save the file again and it works.  What causes this, and is there a way to get around it?
The only time I don't get the error is if I save it again within about a minute of the previous save.
Method of saving:
1) Click Save icon on toolbar
2) Answer Save Now? dialog
3) Get the error popup, click OK
4) Click Save icon on toolbar again
SlickEdit Pro 2023 (v28.0.0.6 64-bit Qt5)
Serial number: [redacted]
License file: C:\ProgramData\slickedit\28\slickedit.lic
Build Date: November 24, 2023
Emulation: CodeWright
OS: Windows 10 x64
OS Version: 10.00.0
Memory: 85% Load, 6943MB/8076MB Physical, 23077MB/32652MB Page File, 5765MB/134217727MB Virtual
Screen Size: 1920 x 1080 (0 0 1920 1080)
Language: .php (HTML)
Encoding: UTF-8, no signature
Installation Directory: C:\Program Files\SlickEdit Pro 28.0.0\ (non-removable drive,NTFS,1674475MB free)
Configuration Directory: C:\Users\ricky\AppData\Local\SlickEdit\28.0.0\ (non-removable drive,NTFS,1674475MB free)
Migrated from: C:\Users\ricky\OneDrive\Documents\My SlickEdit Config\24.0.0\
Spill File: C:\Users\ricky\AppData\Local\Temp\slkspill.ricky.15648 (non-removable drive,NTFS,1674475MB free)
  • Hero Points: 533
Re: PASV error on save
« Reply #1 on: November 27, 2024, 10:16:23 PM »
That's an FTP error. Displayed by macros/ftpq.e line 3950. It looks like it's receiving an unrecognized response. It's trying to parse an address but the address format isn't recognized or is just garbage. There probably isn't a simple work around for this because it can't continue without the address information.
I can't tell more than that without being able to debug the actual ftp site.
jorick
  • Hero Points: 17
« Reply #2 on: November 30, 2024, 04:10:03 PM »
Good grief, I'm a ditz!  :-[  After reading your explanation, I figured that the website was logging me out after a minute or two.  The first save logs back in but maybe SE is getting confused about receiving a login response and generates the error.  The second save actually saves the file.
I turned on keep-alive and now it's working perfectly.  I just have to remember to log out at the end of the session.
