Author Topic: Code annotation menu options greyed out  (Read 1598 times)
rjpontefract
  • Hero Points: 10
« on: December 04, 2024, 09:27:19 PM »
Running SE 28.0.2.0 (Hotfix 19) on Windows 11.
I have the code annotations window docked and the list of annotations looks fine.  Left clicking show the appropriate text in the comment window.  The toolbar buttons on the top right are all active apart from the second to last with the up/right facing arrow on the bottom left of the icon (it has no tooltip so I don't know what it does).
However, right clicking on an annotation in the list shows a menu (new, copy, delete etc.) but all options are greyed out an unusable.  As I can edit or delete using the toolbar buttons I'm surprised I can't use the menu to to the same.
  • Hero Points: 534
Re: Code annotation menu options greyed out
« Reply #1 on: December 05, 2024, 12:58:09 AM »
Reproduced. We will look into this.
  • Hero Points: 534
« Reply #2 on: December 05, 2024, 02:26:09 AM »
Hot fix has been added for this for v29.
Download the hot fix here:
https://www.slickedit.com/hotfixes
Then load the hot fix: Help>Product Updates>Load Hot Fix...
rjpontefract
  • Hero Points: 10
« Reply #3 on: December 05, 2024, 03:39:49 AM »
Thanks!  Is there any chance of a hotfix for version 28?
  • Hero Points: 534
« Reply #4 on: December 05, 2024, 01:10:25 PM »
Only the most recent major version gets new hot fixes.
