Author Topic: Updated from Win 10 to Win 11 and now FTP Client fails to connect  (Read 3058 times)
joecar
  • Hero Points: 9
  • engineer/gearhead
SlickEdit Pro 2024 (v29.0.0.0 64-bit Qt5) with hotfix 4
see attached.
joecar
  • Hero Points: 9
  • engineer/gearhead
Re: Updated from Win 10 to Win 11 and now FTP Client fails to connect
« Reply #1 on: January 23, 2025, 07:46:54 PM »
ssh connects ok from git/mintty.
« Last Edit: January 24, 2025, 02:20:51 AM by joecar »
joecar
  • Hero Points: 9
  • engineer/gearhead
« Reply #2 on: January 23, 2025, 07:49:47 PM »
scp from git/mintty window works ok.
« Last Edit: January 24, 2025, 02:21:02 AM by joecar »
joecar
  • Hero Points: 9
  • engineer/gearhead
« Reply #3 on: January 23, 2025, 08:44:54 PM »
Was working ok previously...
Was using SE v28, and I recently upgraded to v29.
And after that I also upgraded Win 10 to Win 11.
So I don't know which caused the breakage.
« Last Edit: January 29, 2025, 05:48:42 PM by joecar »
joecar
  • Hero Points: 9
  • engineer/gearhead
« Reply #4 on: January 23, 2025, 08:49:28 PM »
WinSCP connects ok.
joecar
  • Hero Points: 9
  • engineer/gearhead
« Reply #5 on: January 23, 2025, 08:58:29 PM »
SE FTP Client say log attached image.
joecar
  • Hero Points: 9
  • engineer/gearhead
« Reply #6 on: January 23, 2025, 09:04:43 PM »
Windows ssh.exe appears to work.
joecar
  • Hero Points: 9
  • engineer/gearhead
« Reply #7 on: January 23, 2025, 10:31:54 PM »
I posted some stuff regarding this here:
https://community.slickedit.com/index.php/topic,19529.0.html
joecar
  • Hero Points: 9
  • engineer/gearhead
« Reply #8 on: January 23, 2025, 10:32:25 PM »
Appears to be due to Win 11 and/or SE v29.
  • Hero Points: 534
« Reply #9 on: January 24, 2025, 02:49:54 PM »
The Windows 11 ssh doesn't work with SlickEdit's SFTP.
If you have git installed, the ssh that comes with it will work.
Or you can download ssh.zip from here:
https://www.dropbox.com/scl/fi/ew5lg2r7dlpooqwivqqo6/ssh.zip?rlkey=xjgv6cgqgwnyh1lcakhy8sge6&st=nj5hdwr7&dl=0
Configure the ssh SlickEdit uses here: Tools>Options>Network & Internet Options>FTP Default Options>SSH/SFTP>SSH Executable
joecar
  • Hero Points: 9
  • engineer/gearhead
« Reply #10 on: January 24, 2025, 07:03:48 PM »
Clark,
I set the Git ssh executable in SE Options as you said above (see first image), and I still get the timeout (see second image).
Previously (SE v28 and Win 10), it would ask me the "Yes/No SSH new key" question and then it would prompt me for the 2FA 6-digit key and the it would connect.
Also:
I tried this using the SE Terminal window using both the Win 11 ssh and the Git ssh, and in each case there appears no response until I punch in the 2FA 6-digit key and then in both cases the terminal window connects.
« Last Edit: January 29, 2025, 05:50:10 PM by joecar »
joecar
  • Hero Points: 9
  • engineer/gearhead
« Reply #11 on: January 24, 2025, 07:09:35 PM »
I also tried using backslashes in the ssh executable pathname, and still get timeout.
joecar
  • Hero Points: 9
  • engineer/gearhead
« Reply #12 on: January 24, 2025, 07:16:21 PM »
When I try either of the Win 11 ssh and the Git ssh in a Windows Shell I am able to connect.
See attached for Win 11 ssh.
joecar
  • Hero Points: 9
  • engineer/gearhead
« Reply #13 on: January 24, 2025, 07:20:37 PM »
( my mistake was to upgrade both SE and Win together... I should have done each separately )
joecar
  • Hero Points: 9
  • engineer/gearhead
« Reply #14 on: January 30, 2025, 06:17:05 PM »
More info (what I know so far):
C:/Windows/System32/OpenSSH/ssh.exe
C:/"Program Files"/Git/usr/bin/ssh.exe
both of those work correctly from the Win 11 Command Prompt and Terminal shells.
They also work correctly from the SE Terminal shell as follows:
you don't see the Yes/No prompt,
you don't see the prompt to enter the 2FA (Google Authenticator) code,
so if you hit ENTER once/twice and enter the 2FA code then ssh connects.
see transcripts of each from SE Terminal:
C:\Users\Joe>C:/Windows/System32/OpenSSH/ssh.exe paz
         <------ hit ENTER here
429337   <------ enter 2FA code
Connection to paz 22 port [tcp/ssh] succeeded!
Welcome to Ubuntu 22.04.5 LTS (GNU/Linux 5.15.0-124-generic x86_64)
Last login: Thu Jan 30 10:03:10 2025 from 172.31.1.70
?2004h(fw3) joe@paz:~#
C:\Users\Joe>C:/"Program Files"/Git/usr/bin/ssh.exe paz
766669  <------ enter 2FA code
Last login: Thu Jan 30 10:04:29 2025 from 172.31.1.70
« Last Edit: January 30, 2025, 06:21:08 PM by joecar »
