Author Topic: uuidgen  (Read 8979 times)
robgreen
uuidgen
« on: July 29, 2006, 03:33:29 am »
I need to generate 100's of guids all the time.. right now i run uuidgen then right click, then paste into slickedit.  i would either like a uuidgen type macro, or someone to tell me how to execute uuidgen and get its output into the clipboard so i can paste it.  i looked at shell() but that doesnt appear to redirect to clipboard.
thanks,
rob
gary_ash
  • Guest
Re: uuidgen
« Reply #1 on: July 29, 2006, 03:00:37 pm »
I wrote an extension dll to insert GUIDs that you may be able to modify
http://www.wideopenwest.com/~gary_ash/SlickMisc.zip
  • Hero Points: 291
Re: uuidgen
« Reply #2 on: July 29, 2006, 03:51:54 pm »
Here we go ...
_command int uuid ()
   _str cmdline = maybe_quote_filename ( "C:\\Programme\\Microsoft Visual Studio .NET 2003\\Common7\\Tools\\uuidgen.exe" ) " > uuid.gen";
   // shell (cmdline,"W"); // strange: 'W' MUST be specified, otherwise 0-byte file is created
   // anyway better to use concur_command() to see what's going on
   concur_command (cmdline, false, true, false, false);
   // sleep 5 * 100ms to 'sync' to execution
   delay(5);
   int orig_wid=p_window_id;
   int temp_view_id,orig_view_id;
   int status=_open_temp_view('uuid.gen',temp_view_id,orig_view_id);
   if (!status)
      top();
      _str uuid;
      get_line(uuid);
      // 'surround with' if needed
      uuid = '{' uuid '}';
      push_clipboard_itype ('CHAR','',1,true);  // use e.g. 'LINE' type to get another paste-behaviour
      append_clipboard_text (uuid);
      _delete_temp_view(temp_view_id);
      p_window_id=orig_wid;
      // add some 'feedback'
      _beep ();
   return(status);
Bind to a key and tell me your uuid/minute rate ;)
« Last Edit: July 29, 2006, 04:11:08 pm by hs2 »
  • Hero Points: 291
Re: uuidgen
« Reply #3 on: July 29, 2006, 03:57:46 pm »
Thanks for sharing it gary_ash !
[thumb-up]
Matthew
  • Hero Points: 44
Re: uuidgen
« Reply #4 on: July 31, 2006, 05:26:27 pm »
I posted a pure Slick-C version that I wrote a couple of months ago in a new top-level topic.
http://community.slickedit.com/index.php?topic=202
robgreen
Re: uuidgen
« Reply #5 on: August 01, 2006, 01:22:10 am »
ok, maybe i am a little thick, but how do i call the function in the dll from slickc?  this is all the help for slickC says..  iow no help..
"DLL interface
SlickEdit products have a DLL interface for Windows. Use the Slick-C macro language instead of the DLL interface except when you need an interface to the DLL in another program, when better speed is needed, or when the Slick-C macro language is missing a function that you want.
After a DLL function is added, call it from a Slick-C macro just like any other Slick-C function. DLL functions can be used for timer call backs and anyplace a Slick-C function is used.
To get started using the DLL interface, edit the simple.c file in the <vslick>\samples\simple directory. The VSAPI functions have the prefix vs.
gary_ash
  • Guest
Re: uuidgen
« Reply #6 on: August 01, 2006, 03:48:56 pm »
you call a dll function just like any other
example:
InsertGUID();
once you execute a dload on the dll functions that it exports really do act just like they're build into Slick-C
if you're still working on the same problem that started this thread I'd suggest you try using the Slick-C guid generator that Matthew wrote. his code will help you generate the bunches of guids that you need I wrote my handle my need to generate the one or two at a time that I some times need
