Author Topic: Set Config Variables  (Read 8323 times)
Lisa
  • Hero Points: 24
« on: August 21, 2007, 03:41:19 PM »
SlickEdit® has many behaviors that are controlled through properties not exposed in the options dialogs. They are set through global configuration macro variables in Slick-C®, by using the menu item Macro > Set Macro Variable, or by using the set_var  command. See the Help Contents item Appendix > Configuration Variables for a list of the most commonly used variables and more information.
