Author Topic: View and Customize Toolbars  (Read 6332 times)
Lisa
  • Hero Points: 23
« on: August 23, 2007, 01:24:54 pm »
Toolbars provide a way to access specific operations quickly while you work, and can be docked so they are always displayed. Check out the View > Toolbars menu and you may discover a toolbar that will help you work more efficiently. Customize your toolbars or create your own (View > Toolbars > Customize), setting up your own buttons and associated operations to gain even more productivity.
jbhurst
  • Hero Points: 33
Re: View and Customize Toolbars
« Reply #1 on: August 23, 2007, 08:59:13 pm »
Or learn to bind commands to keys, and get even more productivity.  ;)
John Hurst
Wellington, New Zealand
