Author Topic: Integrating Borland Help  (Read 9243 times)
rowland51
« on: August 25, 2007, 01:47:58 PM »
Is it possible to configure Slick Edit so that the Boarland help files are accessable ?
For example (just one possible example, I'd want to do other things I'm not listing here because I am not aware of them yet ... ie:   this is a general question - not really specific to JUST THIS ONE EXAMPLE) if I press F1 while the cursor is on a C Language (Borland) function name ... could the Borland help file containing information on that function pop open ?
Thanks
at5dapa1
  • Hero Points: 22
Re: Integrating Borland Help
« Reply #1 on: August 25, 2007, 05:27:13 PM »
Very good question!
I also would like to know if possible to integrate MSDN into SlickEdit. Probably is quite difficult cause every VisualStudio edition has quite different help format, but it would be a huge step further in remaining only inside SlickEdit when programming!  :)
I remember the defunct CodeWright had a such possibility to integrate different external help files ...
So, not urgent, but good idea!
  • Hero Points: 292
« Reply #2 on: August 25, 2007, 06:37:33 PM »
There is a 'msdn_word_help' command but the normal 'F1 -> help' binding is context sensitive and already handles that transparently.
For configuration use 'Help>Configure F1 MSDN Help'.
For other dexplore based help collections (in my case WDK help) I used this simple macro:
_command void wdk_help () name_info (',')
   #define WDK_HELP_ARG          " /helpcol ms-help://ms.WDK.v10.6000 /LaunchFKeywordTopic "
   _str wdk_help = maybe_quote_filename ( get_env( "CommonProgramFiles" ) :+ "\\Microsoft Shared\\Help 8\\dexplore.exe" );
   strappend ( wdk_help,  WDK_HELP_ARG );
   shell (wdk_help :+ maybe_quote_filename( cur_word() ),"AP");
Edit: Note that this collection can also be configured in SE. I used it as workaround to have VS2005 combined help and WDK help available in parallel.
For other simple chm based help files I'm using a (compiled) Autohotkey script. But this is rather a hack than a generic solution.
However - it's better than nothing ;)
« Last Edit: August 25, 2007, 06:52:27 PM by hs2 »
at5dapa1
  • Hero Points: 22
« Reply #3 on: August 26, 2007, 05:10:02 PM »
@HS2: seems that SE is full of surprises! You too!  ;D
Thanks!
