Author Topic: Customize the Right-Click Context Menu  (Read 8257 times)
Lisa
  • Hero Points: 24
« on: August 28, 2007, 02:14:56 pm »
Right-click inside an editor window to access a context menu of operations. A text editing menu appears if there is a selection. If there is no selection, a general list of operations is displayed. You can change the contents of either menu by selecting the submenu item Edit This Menu. Use this to add new operations or remove ones you don't use.
