Author Topic: Files in the Temp directory  (Read 7124 times)
ccdo
« on: August 01, 2006, 09:00:39 PM »
I was trying to clean up my Windows Temp directory and found the following files in C:\Temp\Slick directory. Can these be safely deleted? Or just some of them? Or None?
Thanks.
$slk.0          130432596
$slk.1             373632
$slk.2             852348
$slk.3          109684344
$slk.4          145389552
$slk.5           31735368
$slk.6            1039164
$slk.7             396984
$slk.8             525420
$slk.9             572124
$slk.10         419320188
$slk.11         628087068
$slk.12            315252
And about 3500 files at 40-57K each that are formated like
1832001b23.vtg
1832002b23.vtg
