Author Topic: user defined tags (similar to codewright outline parser)  (Read 14128 times)
blueboy
Re: user defined tags (similar to codewright outline parser)
« Reply #15 on: September 25, 2007, 07:28:55 am »
Hi Guys,
now I managed to change the used tag icon, wasn't really complicated just add something like this:
  proc_type='class';
  proc_args='';
  class_name='';
  tag_flags = VS_TAGFLAG_inclass;
  proc_name=tag_tree_compose_tag(proc_name,class_name,proc_type,tag_flags,proc_args);
It's just the question what you like to have in the tag window.
But my main problem is that I haven't found where to hook into the c_proc_search. If I use
a own c_proc_search this won't be used. So my next idea was to refer the c extension
to an own extionsion (like xyz) and than call the original c routines, but check before own
search function. C extension can't be refered:-(.
Any one an idea where to hook a own search algorithm for c extensions (only with macros, there is no plan to write a dll), it should be extend the original c_proc_search and not replace ?
Something like this should be possible too:
new_c_proc_search(...)
  // check own search function
 if (xyz_proc_search(...)!=0)
   c_proc_search(...);
but where is the hook? ???
