Author Topic: View Commands Associated with Menu Items  (Read 7548 times)
Lisa
  • Hero Points: 24
« on: September 18, 2007, 01:24:49 PM »
Create key bindings for menu operations that you use frequently (for example, Document > Close Buffer). To create a key binding for a menu item, you need to know the associated command. To see the command that is associated with a menu item, click Macro > Menus. On the Open Menu dialog, type or select _mdi_menu, then click Open. The Menu Editor is displayed, with a tree showing each menu item and its associated command. Once you’ve discovered the command, use the Key Bindings dialog to create a key binding (Tools > Options > Key Bindings).
