Author Topic: Omit Comments when Searching  (Read 6560 times)
Lisa
  • Hero Points: 24
« on: October 09, 2007, 01:46:41 pm »
Use the Color button on the Find and Replace tool window (Search > Find) to omit comments when searching. Click the Comment check box until it is cleared. Now your search will only match text that is not part of a comment. See "syntax-driven search" in the Help > Index for more information.
