Author Topic: A Search Shortcut: the Slash (/) Command  (Read 7638 times)
Lisa
  • Hero Points: 24
« on: October 11, 2007, 01:36:47 pm »
A fast way to search for a string is to use the slash command (/). The slash command is the same as the find command, providing the same functionality as the Find and Replace tool window. To use the slash command, simply open the command line and type /SearchString, where /SearchString is the text you want to find.
anura02
Re: A Search Shortcut: the Slash (/) Command
« Reply #1 on: December 27, 2007, 05:09:59 am »
This probably works in VI emulation.
