Author Topic: Reuse Search History with Dialog Box Retrieval  (Read 5778 times)
Lisa
  • Hero Points: 24
« on: November 06, 2007, 04:31:05 pm »
Several dialogs and tool windows keep a history of responses between editing sessions. This is particularly helpful when using the Find and Replace tool window. The window remembers information you’ve entered for all fields, including search/replace strings, look-in location, and option settings, for previous search and replace operations. Press F7 and F8 to retrieve the previous and next search/replace, respectively.
