Author Topic: A couple of problems  (Read 6481 times)
jorick
  • Hero Points: 17
« on: November 30, 2007, 02:26:58 pm »
1) If I have two comment lines in C with the cursor on the end of the first line as shown by the vertical line:
// This is comment 1|
// This is comment 2
and I want to insert a noncomment line between them, how do I do it?  It used to be Ctrl-Enter.  Then it changed to Shift-Enter after an upgrade.  Now it's completely gone.  Typing either Enter or Ctrl Enter results in:
and the new comment slashes cannot be removed.  Typing backspace over it causes the entire comment line to be erased and I'm back to square 1.
How do I revert back to using Ctrl-Enter to open a new noncomment line?
2) If I select and copy a columnar text, and then insert this text multiple times, it performs the insert wrong.  For example, I have the following lines of text in a file:
Var1 = 0;
Var2 = 3;
Var3 = 7;
Var4 = 2;
And I have the following columnar text in the clipboard:
int
int
I put the cursor in front of "Var1" and hit insert twice.  I would expect to see
int Var1 = 0;
int Var2 = 3;
int Var3 = 7;
int Var4 = 2;
but instead I see
int int Var1 = 0;
int int Var2 = 3;
Var3 = 7;
Var4 = 2;
because the cursor didn't drop to the third line after the first insert was done.  This didn't used to be this way.  When I first started using SlickEdit, it worked fine but after an upgrade it broke.
How do I revert to the original operation where the cursor drops to the next line after a columnar insert?
TIA,
Ricky
jorick
  • Hero Points: 17
Re: A couple of problems
« Reply #1 on: November 30, 2007, 03:51:26 pm »
I found the answer to #2 at http://community.slickedit.com/index.php?topic=2385.0.  I didn't see it before because I searched on "column", not "block".
David_O
  • Hero Points: 8
« Reply #2 on: November 30, 2007, 03:57:40 pm »
About the blank line between line comments, unfortunately there is no single keystroke for this when comment wrapping for line comments is on.  We have logged a report and will reexamine the default behavior for the ctrl-Enter key stroke in line comments.  In any case, a solution to insert the blank line easily will be forthcoming in a future release or hotfix.
In the meantime, you can get rid of the extra '//' in the middle line by hitting Home and then Delete twice.  Or use shift+backspace to highlight the '//' and then hit backspace or delete.  Or if you don't really need comment wrapping for line comments, you can turn it off by going to file extension setup (Tools -> Options -> File Extension Setup), then select the Comment Wrap tab and uncheck Enable line comment wrap.
Hope that helps.
dunkers
  • Hero Points: 28
« Reply #3 on: December 01, 2007, 03:42:54 am »
Doesn't shift-enter start a new line without a comment? It does for me, and I don't think I've modified anything.
David_O
  • Hero Points: 8
« Reply #4 on: December 03, 2007, 03:25:50 pm »
Yes.  I should have mentioned that option as well.  Shift-Enter will bypass comment wrapping.  However, that will only work at the end of a line.  You'll split your line if you do Shift-Enter in the middle of text.
Ctrl-Enter will not split the line.  You can think of it as being equal to hitting End and then Enter.
Since jorick mentioned Ctrl-Enter, I was focused on a single key way that also gets the no-split aspect of Ctrl-Enter without the wrapping.  But looking again at his posted example, he has his cursor at the end of line.  Shift-Enter should do the trick in this case.
Thanks for the reminder.
jorick
  • Hero Points: 17
« Reply #5 on: December 03, 2007, 06:32:07 pm »
On my computer, Shift-Enter is mapped to plusminus which expands or collapses selective display blocks.  This is apparently the default functionality because I haven't changed it.  When used at the end of a comment line, it does absolutely nothing.  No carriage return, no characters inserted.  What do I need to map it to to get it to bypass comment wrapping?
I just found it.  it's keyin-enter.  Problem 1 solved.
dunkers
  • Hero Points: 28
« Reply #6 on: December 03, 2007, 06:35:26 pm »
Ah! Don't think I've ever used that one, but I'll make a point of doing it at least once a day now :)
  • Hero Points: 288
« Reply #7 on: December 03, 2007, 07:05:53 pm »
BTW: I think the related commands are (no)split-insert-line. HS2
  • Hero Points: 447
« Reply #8 on: December 11, 2007, 05:43:26 pm »
Another one of my favorite commands is "nosplit_insert_line_before", which is bound to "Ctrl+Shift+Enter" by default in most emulations.
It is easy to remember, if you think of Shift as a modifier for doing something in the reverse direction that the unmodified key sequence does.  That is:  Ctrl+Enter opens a new line after the current line, therefore Ctrl+Shift+Enter should open a new line before the current line.
dunkers
  • Hero Points: 28
« Reply #9 on: December 11, 2007, 06:53:24 pm »
It is easy to remember...
Oh yes, it's just the other 724 commands that are hard  ;D
  • Hero Points: 288
« Reply #10 on: December 11, 2007, 07:08:41 pm »
@dunkers Good one ;D ;D ;D
