Author Topic: File format for Project Properties->Import  (Read 2970 times)
ronneseth
« on: December 05, 2007, 11:13:22 pm »
All,
There is nothing in the help (or in the forums, as far as I can tell) for the "Import" feature under Project->Project Properties {Files Tab}->Import.  What kind of file can you import?  What format must the file be in?
I would like to make a file with a few directories whose files I'd like to put in the project.  Is this feature going to do it for me?
I tried to make a file with a directory on each line, but that just crashed SlickEdit.
Andreas
  • Hero Points: 288
Re: File format for Project Properties->Import
« Reply #1 on: December 05, 2007, 11:20:21 pm »
This can be use to add files to a project specified in a prev. prepared file.
Have a look here for some more details/examples: http://community.slickedit.com/index.php?topic=2038.msg8533#msg8533
Good luck, HS2
ronneseth
« Reply #2 on: December 06, 2007, 12:19:32 am »
Thank you!
...however, it didn't quite fix my problem.
I'm having the same problems as you described in the thread, but the fix didn't work.  Could you please take a look at that thread as I posted a reply to that thread so we keep it all in one place.
Andreas
