Author Topic: Can't change color?  (Read 4326 times)
Wanderer
  • Hero Points: 23
Can't change color?
« on: August 15, 2006, 09:21:55 pm »
Hello,
I'm editing a .aspx file.  Tools->Options->File Extension Setup shows aspx refers to html.
In my aspx file, every line between the <script> and </script> tags has a dark grey background, and I can't find where that can be changed.  Tools->Options->File Extension Setup->Advanced->Color Coding...->Colors...  doesn't have any elements with a dark background.
Any ideas?
Thanks
Ryan
  • Hero Points: 77
Re: Can't change color?
« Reply #1 on: August 15, 2006, 09:27:36 pm »
I believe what you are looking for is the embedded language color.  Go to Tools > Options > Color and click "Set embedded language color".  This should let you choose the background that you want.
Wanderer
  • Hero Points: 23
« Reply #2 on: August 16, 2006, 03:33:48 pm »
Thanks, that is what I was looking for.
