Author Topic: Command line and dialog box search histories not in sync  (Read 2807 times)
bunbun
« on: January 23, 2008, 10:51:11 am »
When I search for items on the command line, and then switch to
the search dialog box, I find that the search string is not set
correctly (to the command line history) even when I have
the "history retrieval" option set.
At the moment, I have hacked my editor to maintain consistency
between the command line and dialog box searches by modifying
find/replace and gui_find/replace. Surely this sort of inconsistency
is not desirable? (This is longstanding slickedit behaviour)
Leo
  • Hero Points: 288
Re: Command line and dialog box search histories not in sync
« Reply #1 on: January 23, 2008, 11:22:52 am »
Agreed. I've also modified some things to workaround this issue for me, but I'd be happy to throw away these patches.
A consistent search/replace string history would be sufficient and a big help as the search flags are not fully 'compatible'.
