Author Topic: How to Beat Down an "else" Statement in Three Keystrokes  (Read 5837 times)
Lisa
  • Hero Points: 24
« on: January 29, 2008, 04:43:50 pm »
Suppose you want to get from something like this:
       if ( cond ) {
          doSomething();
       } else {
          goSomewhere();
          doSomethingElse();
          comeBack();
          takeANap();
To this:
       if ( cond ) {
          doSomething();
       goSomewhere();
       doSomethingElse();
       comeBack();
       takeANap();
1. First, put your cursor on "else" and press Ctrl+Shift+Right to select it.
2. Press Enter.
3. Press Ctrl+Delete, and select Unsurround the code block.
Though Unsurround does not normally apply to "else" blocks, this example shows how you can manipulate your code to make a feature work for you in order to save time.
