Author Topic: Tilde key on ThinkPad  (Read 6244 times)
j
« on: August 18, 2006, 07:42:36 PM »
On my ThinkPad T23 the Tilde key does not work, while in all other applications, it works.
The system is Linux 2.6.14 with KDE 3.5 desktop. Changing the keyboard layout did not help.
Has anybody got an idea, how to get the Tilde key to work?
Kohei
  • Hero Points: 25
Re: Tilde key on ThinkPad
« Reply #1 on: August 23, 2006, 07:41:04 PM »
What output do you get when you run xev from the command line and press the tilde key?  Would you mind showing us the output?
j
« Reply #2 on: August 25, 2006, 07:50:49 AM »
I found the problem, or better, the solution to the problem. If the LANG variable is not set, you get this behaviour. As soon as as you set LANG to something (need not match the keyboard language), it works.
I remembered that OpenOffice once (or still?) showed the same behaviour. Probably has to do with some library used by both these products.
Probably something for the FAQ!
