Author Topic: Can Build->Select Configuration drive Selective Display  (Read 5771 times)
Wanderer
  • Hero Points: 23
« on: August 19, 2006, 01:05:19 pm »
This thread -- http://community.slickedit.com/index.php?topic=276.0 -- suggested a new feature.  (Maybe it can already be done.)
It would be handy to be able to select a configuration (Build->Set Active Configuration) and have a certain set of tokens get defined for Selective Display.  Perhaps there is a _proj... or _project... handler that could be used.
It looks like _prjconfig_xxx might work.  The next challenge is setting the tokens for Selective Display, and then activating it.
« Last Edit: August 19, 2006, 01:12:12 pm by Wanderer »
  • Hero Points: 291
Re: Can Build->Select Configuration drive Selective Display
« Reply #1 on: August 22, 2006, 08:50:12 am »
You may tweak your project setup using the 'Open command' feature.
http://community.slickedit.com/index.php?topic=259.0
I'm going to make use of it to switch my C-Compiler tagfile setup for my Windows- and my embedded projects.
dunkers
  • Hero Points: 36
« Reply #2 on: August 22, 2006, 04:48:27 pm »
Am I missing something here? To change tag files (I have several embedded compilers along with Borland and Microsoft windows one) in the project properties I use the Compile/Link tab to specify the compiler.
I had missed that but support very kindly put me straight when I whinged about my sticky VC++ tag file...
Wanderer
  • Hero Points: 23
« Reply #3 on: August 22, 2006, 06:14:38 pm »
I'm not sure that will do what I want.  According to the on-line help:
Commands can be entered for projects that are executed when the project is activated. This information is stored per project, not per configuration.
I'd like per-configuration settings.  It is unclear from the Help as to what sorts of commands you can use, and where they are applied.
I'd like to do something like this:
preprocess XVTWS=1 MTFWS=7 XOLWS=5 WINWS=1 WIN32 MACWS=0 XmVersion=1 XVT_TEXTEDIT
Unfortunately, typing that in to the Open command window just sent SlickEdit on a long trip south...
  • Hero Points: 291
« Reply #4 on: August 22, 2006, 10:11:36 pm »
@Wanderer:
Similar things happened to me when adding some stuff to the 'Open' commands.
@see http://community.slickedit.com/index.php?topic=264.msg1006#msg1006
Maybe commenting (as I did) the ref'd paragraph helps.
@dunkers:
Is it that simple ... I completely ignored that b/c mostly I roll my own build env.
It's a bit confusing that all avail. tagfiles are always visible in the tagfile list...
However, thanks a lot !
