Author Topic: Vertical scroll bar widget "thumb box" size  (Read 8408 times)
  • Hero Points: 348
« on: August 19, 2006, 11:59:05 PM »
Anyone using the vertical scroll bar widget on a vslick form (with Windows XP SP2, slick 11.0.1)?
I can't get the "thumb box" (the thing that can be dragged) to show as anything other than one fixed small size.  The size of the thumb box should get larger as the number of "items" gets smaller  e.g. for p_min and p_max of 0 5, the thumb box is the same small size as for p_min p_max 0 30000.  Does the thumb box change size for anyone?
