Author Topic: Slickedit and cmake ?  (Read 20770 times)
guth
  • Hero Points: 7
Re: Slickedit and cmake ?
« Reply #30 on: December 12, 2019, 08:03:59 PM »
I got that as well, but downloading the source provided by slickedit and building cmake myself solved that issue.
patrickkox
  • Hero Points: 6
  • Debian GNU/Linux user
« Reply #31 on: December 12, 2019, 08:07:29 PM »
I'm actually doing the same now (started when I was posting my reply), but if it doesn't work with SlickEdit 2019 it doesn't really matter.
patrickkox
  • Hero Points: 6
« Reply #32 on: December 13, 2019, 01:34:07 PM »
I've just compiled the version 3.8 of the SlickEdit cmake sources posted here and it seems to work with SlickEdit 2019.So what did I do :
  • Download the Linux sources for the Project Generator (https://support.slickedit.com/outbound/cmake/cmake-3.8.0/cmake-3.8.0_src.zip).
  • Extracted into a temp directory, entered that directory, made bootstrap executable, made a directory called build and ran bootstrap from that directory.
  • ran "$ make" and after that "$ make install".
  • Created a simple "Hello World" program (just one main.cpp file).
  • Made a CMakeLists.txt file with the basic information for the build and put it in a directory called "MakeFiles".
  • Ran the Project generator (cmake -G SlickEdit - Unix Makefiles).
  • Got an error and installed the ninja-build tool ($ sudo apt install ninja-build).
  • re-ran the cmake command.
this made 1 SlickEdit Workspace called "Hello" and 2 Projects
  • BUILD_ALL
  • Hello
So for the little I've tested the project generator seems to work well with SlickEdit 2019 on Debian Buster, but I didn't see an "execute" option to start the compiled program after the build (as is with a "normal" C++ project when started from within SlickEdit) so if this could be added that would be nice. Or better yet, full CMake integration  ;)
Hope this helps anyone.
« Last Edit: December 14, 2019, 01:09:28 PM by patrickkox »
JeppeOland
« Reply #33 on: January 14, 2020, 01:16:25 AM »
Did anybody (SlickEdit guys?) port up to recent versions of CMake?
  • Hero Points: 531
« Reply #34 on: January 14, 2020, 02:46:18 PM »
Version 3.14.5 is here:
https://support.slickedit.com/outbound/CMake/cmake-3.14.5/cmake-3.14.5_src.zip
https://support.slickedit.com/outbound/CMake/cmake-3.14.5/cmake-3.14.5_src.tar.gz
https://support.slickedit.com/outbound/CMake/cmake-3.14.5/cmake-3.14.5-win64-x64.zip
https://support.slickedit.com/outbound/CMake/cmake-3.14.5/cmake-3.14.5-Linux-x86_64.tar.gz
https://support.slickedit.com/outbound/CMake/cmake-3.14.5/cmake-3.14.5-Darwin-x86_64.tar.gz
Note that the Linux version of cmake version 3.14.5 would not build on our standard Linux build machine. This means it's much more likely it won't run on your version of Linux and that you will have to build it.
We will look into updating this to 3.16.2 which is the latest version.
« Last Edit: January 14, 2020, 02:48:37 PM by Clark »
JeppeOland
« Reply #35 on: January 15, 2020, 05:28:22 PM »
Awesome - thanks!
patrickkox
  • Hero Points: 6
« Reply #36 on: November 21, 2021, 07:37:32 PM »
Clark,
With the recent release of Debian 11, is there a chance of getting a version 3.18.4 of CMake (that's the version that comes with Debian 11)?
  • Hero Points: 531
« Reply #37 on: November 22, 2021, 03:15:34 PM »
patrickkox
  • Hero Points: 6
« Reply #38 on: November 23, 2021, 04:46:54 PM »
Thanks!
