Author Topic: How do I get a file without any extension recognized by SlickEdit as a C file ?  (Read 18904 times)
bohemian
I am incorporating a 3rd party software into my project and for some reason the header files in the 3rd party source code do not have any extension at all !!!
I am unable to get SlickEdit to recognize these files as C header files nor get them tagged. The file extension setup works only for files which actually have an extension. I even tried to create a new extension by typing just a "." but that didn't work either.
Does anyone know of a hack/workaround/solution for this issue. Thx !
  • Hero Points: 291
Check your file ext setup -> tagging -> Options ...
bohemian
The picture that you have posted seems to be for the extension "c". I don't have a problem with the files with a ".c" or a ".h" extension. My issue is with a C header file that doesn't have a ".h" extension. In fact it doesn't have any extension at all.
So if I have a file "foo.c" or a "foo.h" they get recognized and tagged correctly by SlickEdit but a file name of just "foo" doesn't get recognized or tagged even though it contains C code.
I just can't figure out how to get SlickEdit to recognize this file.
  • Hero Points: 291
Take a closer look ;)
The pic belongs to the common C/C++ 'file extension setup' -> see button 'Options...' at the bottom of the dialog -> see 'C Options' -> Other Tab -> see 'Extensionless C++ files'. Add your STL / whatever headers there...
Don't care about the ExAcT words, it's the common C/C++ setup.
Good luck,
bohemian
I didn't have the "Extensionless C++ files" tab in my version of SlickEdit (10.x) so I upgraded to the latest version (11.x) and then this tab showed up.
Per your recommendation I added about 5 files (extensionless C header files) and then forced a re-tag of the project. But still no luck. When I open up the files they just display as regular text files no special formatting can be seen. Also the symbols in these files are not tagged since I couldn't jump from the function implementation in the C file to its declaration in the corresponding "extensionless" C header file.
Am I missing a step ? I thought retagging after adding these extensionless files should've done it.
Any help/insight would be appreciated.
  • Hero Points: 291
Did a quick check how it's handled by Slick.
These files are considered as part of the C-Compiler (auto-)tag file.
I hope a rebuild of it solves the problem.
See 'Tool->Tag Files->Auto Tag... button'
Good luck,
BTW: The mapping of these files to 'C-files' is also built in.
Should work ... at least when you get into such a file by 'Goto Definiton' or something.
« Last Edit: August 23, 2006, 05:34:51 pm by hs2 »
bohemian
Nope that didn't work either ! I even tried to delete the complete project and start from scratch but those files just don't get recognized.
Looks like I am left with only one choice i.e. to rename all the extensionless C header files with a ".h" extension and then painstakingly append all the refrences to these header files  in the C source files with ".h". With more than a thousand files in the 3rd party software that I am porting, it is going to be a stupendous task.
I really thought that SlickEdit would've handled this case better. Perhaps there is a way to do this but doesn't look like anyone has faced this particular issue before.
Thanks for trying H2S.
Phil Barila
  • Hero Points: 61
If you haven't already, call the support line or send a request to the support@slickedit.com.  At least make them tell you it can't be done before you give up.
  • Hero Points: 291
Holy sh*t - was not that easy...
But I think I got it...
1. By default it's required that your ext.less headers reside in certain subdirs (e.g. include subdir) !
on cmdline use e.g.:
set-var def_cpp_include_path_re inc|include|c\+\+|g\+\+-2|g\+\+-3
to add a new subdir prefix inc.
or just:
to check and edit this regexp. (It's not CaSe sensitive on Windows.)
2. add your ext.lessies w/o any path to the Ext.Less C++ list (see attachment)
or on cmdline:
set-var def_user_langext_files my ext less files
3. add the files - using 'All files *.*' mode ;) - to your workspace tagfile (Tools -> Tag Files dialog again).
4. retag
Worked for me (tag support + colorizer) and should work for you - I hope ...
« Last Edit: August 23, 2006, 11:22:08 pm by hs2 »
  • Hero Points: 465
As a side note:  Anyone else just want to break the kneecaps of the guy on the standards committee who came up with this idea of extensionless header files?
  • Hero Points: 291
Fully ACK :)
That's the problem w/ such committees !
In addition the members are often 'spare' guys sent by their companies to take care about politcal interests ... any questions ?
PlanetPratt
  • Hero Points: 6
Then again, I've been telling SlickEdit for years that they should switch from extensions to filespecs.  So instead of specifying .c, you'd specify *.c.  That way you could specify Makefile as a pattern or (in this case) inc/*.  It would make the tool much more flexible, and I can't really see a down side.
  (*Chris*)
spowers
Is there a better way to do this?
I'm using the OSG library and there are hundreds of extensionless files within a directory structure.
Is there a way to include a recursive directory path rather than listing all the files I have in the library?
  • Hero Points: 291
Maybe these files are magically recognized as C++ files by SE and you don't need to do anything...
Are they colorized / tagged correctly ?
Sorry - this won't do.
I've added this (hack) time ago to handle (well - colorize at least) ext. less files via '_buffer_add_' callback:
void _buffer_add_hs2 ( int bid, _str bname, int bflags )
   int draw_box_option = ( p_mode_name :!= 'Fundamental' ) ? VSCURRENT_LINE_BOXFOCUS_INDENT : VSCURRENT_LINE_BOXFOCUS_TABS;
   if ( draw_box_option != _default_option('u') )
      _default_option('u', draw_box_option);
   if ( (p_extension :== '') && (p_mode_name :== 'Fundamental') )   select_edit_mode( 'c' );
But I don't think this affects tagging engine...
« Last Edit: December 13, 2007, 09:13:59 pm by hs2 »
spowers
I've gotten them to colorize by editing the .fundamental  file extension setup.
Through that option I can get the extensionless files to colorize like cpp files but I am unable to get them to tag properly.
Is there no support for this feature?
