Author Topic: Changing VSLICKCONFIG on Windows  (Read 6943 times)
skywise
  • Hero Points: 10
« on: August 23, 2006, 06:01:16 pm »
Using VSlick 11.0.1 on Windows...
My company has setup our My Documents directory so that they're network shares.  (ooh, easy backup)
The downside is that there's occasional network latency and such which makes slickedit unhappy (that and doing file swapping and such over the share is bad).
according to help, you're not supposed to change VSLICKCONFIG in the vslick.ini file... I've tried "setting" the value from within the program itself but a restart just set it back.  Where can I actually, safely, change this value at?
  • Hero Points: 291
Re: Changing VSLICKCONFIG on Windows
« Reply #1 on: August 23, 2006, 06:57:15 pm »
Due to the fact that this is the 'root' setting you've to add
a VSLICKCONFIG env. variable e.g in your USERPROFILE.
« Last Edit: August 23, 2006, 06:59:33 pm by hs2 »
  • Hero Points: 466
« Reply #2 on: August 24, 2006, 02:23:08 pm »
Also, if you launch SlickEdit consistently using a shortcut, you can just add the "-sc" option to the command line for the shortcut.  For example, my shortcut for launching SlickEdit has the following "target":
E:\slickedit-11.0.1\win\vs.exe -sc e:\slickedit-11.0.1\config\ +new
This eliminates the need for setting VSLICKCONFIG.
