Author Topic: Bug: Double-end tags inserted in HTML mode  (Read 6751 times)
chrisant
  • Hero Points: 131
« on: March 30, 2008, 09:38:27 pm »
When I type in HTML mode, depending on the nearby tags it can insert two end tags on different lines.
Here is a small sample file that reproduces the problem:
1.  Open the attached repro.htm file in SE 2008.
2.  I have adaptive formatting off for HTML.
3.  Move the cursor to the end of line.
4.  Type
EXPECTED:  a matching
should get inserted immediately following the .
ACTUAL:  a matching
does get inserted immediately following the , but also a second get inserted immediately after the <li> on the following line.
David_O
  • Hero Points: 8
Re: Bug: Double-end tags inserted in HTML mode
« Reply #1 on: March 31, 2008, 02:31:49 pm »
Thanks the feedback.  I was able to reproduce that.  We make this a high priority for the next release or hotfix.
David_O
  • Hero Points: 8
« Reply #2 on: May 07, 2008, 02:24:30 pm »
A hotfix has been released to address this issue.
Thanks for helping us find this.
chrisant
  • Hero Points: 131
« Reply #3 on: May 07, 2008, 06:03:55 pm »
Confirmed, it fixes the scenario.
