Author Topic: Working directory issue still not resolved  (Read 2967 times)
danblanks
« on: August 25, 2006, 09:34:41 pm »
I'm still having a problem with the Working Directory switching after
setting the def_switchbuf_cd variable. While setting this variable
stops the Open File dialog from switching directories, it has the
unwanted side effect of forcing the debug directory to be the same
as the directory last used to open a file. As these directories are
necessarily different for my setup, this means I have to turn off
the def_switchbuf_cd variable to debug my program.
I have the "Run from dir" field in the Debug configuration set to
the desired directory, but slickedit appears to ignore this setting
when def_switch_cd is turned on.
Any solution would be appreciated...
