Author Topic: Color schemes  (Read 51774 times)
  • Hero Points: 288
Color schemes
« on: August 27, 2006, 08:59:44 am »
I think it's a good idea to start a thread where color schemes can be shared.
I'm sure there a lot of well-designed schemes out there...
Append it to your VSLICKCONFIG/uscheme.ini file, (re-)start Slick and select it - it will certainly hurt your eyes ;)
(contains 'HS2 Dark Blue (+embedded)' scheme)
« Last Edit: August 27, 2006, 09:02:34 am by hs2 »
natros
Re: Color schemes
« Reply #1 on: August 27, 2006, 07:13:39 pm »
Here is mine
natros
Re: Color schemes
« Reply #2 on: August 31, 2006, 05:17:10 pm »
... and you can get the truetype fonts (MiscFixedSC613, MiscFixedB613) from http://www.twoevils.org/html/files.html
  • Hero Points: 288
Re: Color schemes
« Reply #3 on: September 08, 2006, 02:52:43 pm »
aperry
Re: Color schemes
« Reply #4 on: January 03, 2007, 10:20:28 pm »
Well, we seem to have devolved into a bit of a fonts discussion, so I'll throw out the one that is the best free font I have found for programming.  Dotted zeroes, clear distinction between 1, l, and I, etc.
It is the DejaVu Fonts.
They were developed based off of the Bitstream Vera fonts, and have added a ton of international characters (still lots to go).
Anyhow, check it out, you won't be disappointed.
cycloptic
Re: Color schemes
« Reply #5 on: February 28, 2007, 01:12:47 pm »
Would it be inappropriate to post colorschemes ported to SlickEdit from other apps?
I have a few schemes that I borrowed from VIM that I like to use.
cycloptic
  • Hero Points: 288
Re: Color schemes
« Reply #6 on: February 28, 2007, 01:16:35 pm »
Of course not - AFAIK threre are no copyrights on color schemes ;)
cycloptic
Re: Color schemes
« Reply #7 on: October 24, 2007, 05:17:10 pm »
Sorry for the delay.
Here are a few color schemes I like to use. Some were adapted from VIM and a few other editors I have run across.
The first one is a dark theme based on VIM's Zenburn.
cycloptic
« Last Edit: October 24, 2007, 05:27:36 pm by cycloptic »
cycloptic
Re: Color schemes
« Reply #8 on: October 24, 2007, 05:18:45 pm »
Here is another dark one based on VIM's OceanDeep.
cycloptic
cycloptic
Re: Color schemes
« Reply #9 on: October 24, 2007, 05:21:07 pm »
This one is somewhat light though subdued called "parchment-emph"
cycloptic
cycloptic
Re: Color schemes
« Reply #10 on: October 24, 2007, 05:23:10 pm »
Another dark one called Wombat. (I think this came from a VIM theme also.)
cycloptic
cycloptic
Re: Color schemes
« Reply #11 on: October 24, 2007, 05:25:05 pm »
Here is a somewhat blue theme. Goes well with XP's default.
cycloptic
cycloptic
Re: Color schemes
« Reply #12 on: October 24, 2007, 05:26:34 pm »
One more.
Another light one called Desert.
cycloptic
rsadeh
Re: Color schemes
« Reply #13 on: November 22, 2007, 06:56:17 am »
I've tried the color schemes in this thread. I've appended them to my vsscheme.ini (I have version 12.0.3 and I've noticed that HS2 wrote uscheme.ini) and when I try some of them I get the error msg "Invalid color. Unable to update sample".
What could be the reason for that? Is this some incompatibility between old/new versions?
thanks.
Ding Zhaojie
  • Hero Points: 37
Re: Color schemes
« Reply #14 on: November 22, 2007, 07:35:02 am »
My color schemes: Water Color, IceAge, Borland Classic. My favorite is "Water Color".
