Author Topic: Where is user.vlx in Core  (Read 9749 times)
bercikr
« on: April 11, 2008, 06:11:30 pm »
Where is user.vlx(or equivalent file) stored in Eclipse Core 3.3? Also can you force the SE Core plugin to reload this file without restarting?
Ryan
  • Hero Points: 77
Re: Where is user.vlx in Core
« Reply #1 on: April 14, 2008, 01:53:20 pm »
In your config directory, as user.vlx.  Just go to Help > About SlickEdit Core to see where your configuration directory is located.
Yes.  If you have changed user.vlx behind the scenes, go to Window > Preferences > SlickEdit > General > Color Coding and hit OK.  SlickEdit should reload the changes into the lexer, and you will be good to go.  Let me know if this doesn't work for you.
- Ryan
« Last Edit: April 14, 2008, 01:56:03 pm by Ryan »
