Author Topic: Custom Key Bindings in Search Results Window  (Read 20938 times)
Lisa
  • Hero Points: 24
« on: April 17, 2008, 03:12:46 PM »
Did you know that the Search Results window has its own custom bindings for keyboard navigation?
  • Enter - Like double-click, pressing Enter will go to the current search result.
  • Ctrl+Up/Ctrl+Down – Jumps to previous/next file in the search results list.
  • Delete – Deletes current search result line. If the current line is the File line, it deletes all the results from that file as well. (And Undo is available in case you delete too much).
There is also a right-click context menu available with additional tools. See "Find in Files tab (Find and Replace)" in the Help > Index for more information.
