Author Topic: Navigate to an Overloaded Operator  (Read 6012 times)
Lisa
  • Hero Points: 24
« on: April 22, 2008, 01:50:52 pm »
Did you know that you can use Ctrl+Dot to navigate to an overloaded operator in C++? Go to the line containing "toDo == toEat" and put your cursor on "==", then press Ctrl+Dot.
class Something {
public:
    bool operator == (const Something &rhs);
    bool operator != (const Something &rhs);
bool Something::operator ==(const Something &rhs) {
   return true;
bool Something::operator !=(const Something &rhs) {
   return !this->operator ==(rhs);
void main(int argc, char argv[])
   Something toDo;
Something toEat;
   if ( toDo == toEat ) {
       printf("It's time for lunch.\n");
raj2all
Re: Navigate to an Overloaded Operator
« Reply #1 on: May 06, 2008, 07:46:27 am »
that's good feature I was not aware of.
But it seems like this feature is not working for Function call operator ( () )
Regards
