Author Topic: Tags in unnamed internal structure are not detected.  (Read 4011 times)
AlexBi
« on: August 30, 2006, 06:51:36 am »
I encounter a strange behavior of tagging in such structure
typedef struct {
  struct {
    int fld1;
    int fld2;
  } ss1;
} stru_type;
Than if I type (in body of some function)
stru_type s;
s.ss1.
I shall not see list of fld1 and fld2. If I give any name to internal structure tagging will work fine. Do I want something strange or is this a feature of SlickEdit?
  • Hero Points: 291
Re: Tags in unnamed internal structure are not detected.
« Reply #1 on: August 30, 2006, 08:21:04 am »
Maybe fixed in v11.02
* Fixed bug where find-tag fails for member of local object within
        anonymous class.
