Author Topic: Making Changes to top menu (_mdi_menu)  (Read 6789 times)
bercikr
« on: April 30, 2008, 04:58:22 pm »
Ryan,
    I was wondering if its possible to add menu items to the top menu like it is in SlickEdit 2008. I made some changes to the _mdi_menu, but I did not see these reflected in Eclipse. Is there some way to do this?
Rob
Ryan
  • Hero Points: 77
Re: Making Changes to top menu (_mdi_menu)
« Reply #1 on: April 30, 2008, 09:12:22 pm »
Unfortunately, not directly through SlickC  :-[.  Those menus up there are populated/created through Java, since that area is part of the actual Eclipse GUI.  You would have to write a plug-in for Eclipse to modify anything like the Tools or Macro menu, or to add one of your own.
- Ryan
