Author Topic: add files ending with *.XML to xml file extension.  (Read 8927 times)
zohar81
« on: May 07, 2008, 06:50:34 am »
Hello,
i'm looking for help in adding files that end with XML to the xml file extension which currently include only *.xml files.
the reason for this act, is to get a convenient format for my XML files (with colors and stuff)
i tried looking in toolbar: tools -> file options -> file filters, but it didn't work, perhaps some of you know how to do it ?
thanks,
  • Hero Points: 291
Re: add files ending with *.XML to xml file extension.
« Reply #1 on: May 07, 2008, 10:22:23 am »
In v12.0.3 you've to use 'Tools>Options>File Extensions: New' and use 'Refer to:xml'.
