Author Topic: Lost my key bindings  (Read 3142 times)
tmadorma
« on: August 31, 2006, 01:48:24 pm »
Hi,
I just downloaded the trial version of SlickEdit and spent a while to set all of my key bindings, and they worked very well. Then I setup my project and workspace and then opened some files. It seems that my key bindings have now vanished.. Are key bindings specific to workspace or project? Maybe loosing my key bindings have nothing to do with my setting up the workspace and project. What file should I look for to see if my configured key bindings are someone on my PC?
thanks,
Tim
  • Hero Points: 325
Re: Lost my key bindings
« Reply #1 on: August 31, 2006, 06:43:47 pm »
If you still have slickedit open, type list-keydefs at the slick command line (press escape within slick to bring up the command line or click on the status bar) to see your key bindings.
Alternatively, if slick isn't open, find your slick config directory and open vusrdefs.e in notepad or something - your key bindings should be at the start.
