Author Topic: How to config slickedit 11 per a spcified tornado installation?  (Read 5886 times)
moshebir
Hello!
I have different 2 tornado installations on my P.C.
I open the workspaces with slickedit 11 and also compiles, builds and rebuilds it with slickedit 11.
How can I check which tornado installation is used by slickedit doing these actions?
Can I change the installation used by slickedit?
How?
Best regards,
M.B.
marco
Re: How to config slickedit 11 per a spcified tornado installation?
« Reply #1 on: July 06, 2008, 12:20:56 pm »
Under SlickEdit, you have the possibility to open the cmd line (OS Shell option), there just look at your environment c:>env
and see on which installation the WIND_BASE is directed.
You can move to another Tornado installation just by modifying this env varaible.
Marco
