Author Topic: Problems starting SlickEdit  (Read 5369 times)
markus
« on: May 29, 2008, 01:54:04 PM »
Hello,
i have some Problems with starting SlickEdit on my LinuxSystem.
If i call "vs" i get the messages :
Fontconfig warning: line 73: unknown element "cachedir"
Fontconfig warning: line 74: unknown element "cachedir"
SlickEdit isnt starting after that.
Trying on Fedora Core 8 in a virtual VMWare Machine
SlickEdit Version 11
Can anyone give me a hint where to look?
So i can bring my lovely SlickEdit up to run.
Thanks
Markus
  • Hero Points: 292
Re: Problems starting SlickEdit
« Reply #1 on: May 29, 2008, 04:17:40 PM »
Try 'Search' the forums .. you would find  this posting ;)
claypan
« Reply #2 on: June 03, 2009, 02:37:57 AM »
hi, I a green hand ,I still had the same problem.
I install it at fedora10,
I had try VisualSlickEdit12.03forlinux,VisualSlickEdit11.01forlinux,SlickEdit2009v14.0.0.7,se_14000102_linux_full.tar,
all of them can not start ,it seems hold ,when follow info come out
I search all  help ,but ,they problem is in "fine"
my problem is ,SE can not start ,
I don't know why,
thanks for help
ps: hi markus, how did you solve this problem? thanks
