Home
Help
Search
Login
Register
SlickEdit Community
Archived Beta Discussions
SlickEdit® Core for Eclipse
Slick Edit Error
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Slick Edit Error (Read 9260 times)
jameslorr
Community Member
Hero Points: 0
Slick Edit Error
on:
June 04, 2008, 03:31:56 PM »
Got the following error when trying to "Add Files" to a Tag File set. Anyone seen this before?
Logged
bercikr
Community Member
Hero Points: 2
Re: Slick Edit Error
Reply #1 on:
June 04, 2008, 05:12:34 PM »
Thats a pretty standard JVM crash window. Your Eclipse workbench is dying and it could be for any number of reasons. Sometimes it can be memory related or a bug in one of your installed plugins, has this happened more than once?
Logged
jameslorr
Community Member
Hero Points: 0
Reply #2 on:
June 04, 2008, 05:24:55 PM »
It happens every time I try to do something with the Tag Files. Whether it be adding a single file, a tree or whatever. I am trying to create some standard tag files for my Java libraries & WindRiver OS directories, but as soon as I click on the button, it crashes
Logged
bercikr
Community Member
Hero Points: 2
Reply #3 on:
June 04, 2008, 05:29:30 PM »
Something probably got messed up in your SlickEdit config directory then. Try shutting down eclipse and deleting your SlickEdit Core config directory
My Documents\My SlickEdit Core Config
and then restart eclipse. This will make SlickEdit think it was just installed and send you through the slickedit initialization process again. Hopefully this will fix your issue.
Logged
jameslorr
Community Member
Hero Points: 0
Reply #4 on:
June 05, 2008, 12:56:58 PM »
Thanks, that seems to have solved the problem.
Logged
Print
Pages: [
1
Go Up
« previous
next »
SlickEdit Community
Slick Edit Error
