Author Topic: Language-Specific Options Shortcut  (Read 9101 times)
Lisa
  • Hero Points: 24
« on: June 10, 2008, 04:37:09 pm »
If you need to set or check language options frequently, it can be bothersome to always click Tools > Options > Languages, expand your language category and language and then click the option node you want. Sure, the Options dialog remembers where you were last, but if you weren't there last, that's not much help. Fortunately, there is a shortcut to the language options if you have a file open in that language: From the main menu, simply click Document > [Language] Options.
PS. If you have a tip that you think would be useful to the community, feel free to send it to docs@slickedit.com for consideration!
« Last Edit: June 10, 2008, 04:39:44 pm by Lisa »
