Author Topic: Editor Control on_change event  (Read 8949 times)
ronburk
  • Hero Points: 3
« on: September 02, 2006, 05:22:49 PM »
There doesn't seem to be an on_change event for Editor Controls.
How do I, well, detect when a change has been made?
ronburk
  • Hero Points: 3
Re: Editor Control on_change event
« Reply #1 on: September 02, 2006, 08:11:09 PM »
Right now, just the typical: "Save" button is enabled/disabled
to indicate whether there are unsaved changes in the
Editor Control.
I considered the "hook every dang thing" approach, but worried
I would miss some route to modifying the buffer. So now I poll
the p_modify flag with a timer (ugh). Hard to decide which evil
is lesser.
It seems very strange to have an on_change event for other
object times and not for the Editor Control.
On the bright side, I found there is an xml_mode() method
for Editor Controls, even though no such method appears in
the documentation.
  • Hero Points: 347
« Reply #2 on: September 02, 2006, 11:39:49 PM »
There is the VSCALLBACK_AR_BUF_TEXT_CHANGE callback  -  dunno if it works though.
I use a timer for this - works fine for me.
You could also modify the _update_mod_file_status in bufftabs.e or the _as_callback function in autosave.e to add a call to your own function.
ronburk
  • Hero Points: 3
« Reply #3 on: September 06, 2006, 04:09:07 AM »
Thanks for the additional tips!
