Author Topic: Expanding/Collapsing Nodes in the Options Dialog  (Read 9614 times)
jjones
  • Guest
« on: June 24, 2008, 01:14:30 pm »
In the tree in the Options dialog (Tools > Options), you can expand all nodes, collapse all nodes, or expand the children of a node by using the right-click context menu.
You can also expand/collapse a node with the Right/Left arrow keys.
