Author Topic: Keyboard Shortcuts in the Options Dialog  (Read 17694 times)
jjones
  • Guest
« on: July 01, 2008, 01:02:21 pm »
The Options dialog (Tools > Options) supports keyboard shortcuts. Here are a few:
  • Alt+O jumps from the option tree to the option panel on the right.
  • F4 toggles combo boxes up/down, enables text boxes, and displays color and directory pickers.
  • Alt+Left and Alt+Right navigate backward/forward between previously viewed option panels.
  • Enter saves any changes and closes the dialog.
See "Options dialog shortcuts" in the Help > Index for more shortcuts and information.
afflictedd2
  • Guest
Re: Keyboard Shortcuts in the Options Dialog
« Reply #1 on: October 25, 2010, 07:36:52 pm »
How do I jump from the search box in the options dialog box to the trees.. this would help a lot.. as I hate to move my hand towards my mouse to select what I just found.
Ted.
  • Hero Points: 341
« Reply #2 on: October 26, 2010, 07:41:12 am »
If you're keen, put this in a macro file and load it - function key F2 then gets you from the search box to the tree.  It seems to work but don't blame me if it crashes one day...
#include "slick.sh"
defeventtab _options_tree_form;
void _options_tree_form.f2()
   int treeWid = _find_control('_ctl_tree');
   if (treeWid) {
      treeWid._set_focus();
